It is currently Fri Jul 18, 2025 9:12 am
 Post subject: Matte Finish Question
PostPosted: Fri Dec 01, 2017 11:20 pm
First name: Dale
Last Name: Peterson
City: Bloomington
State: MN
Zip/Postal Code: 55420
Hello.
After some searching through the other threads, I didn't find anything that would really answer my question.
I have a Les Paul kit with a mahogany body and flame maple top. I have a color I want to stain the body, but I want to obtain a matte finish. Still something that will protect the wood (I live in a climate that is very unforgiving), but matte - almost natural finish.
Can I get some input on the best way to achieve that desired feel?
PostPosted: Sat Dec 02, 2017 1:00 am
There are various flat finishes available on the market, and then there are techniques for flattening many finishes. That's a place to start and consider your direction.
PostPosted: Sat Dec 02, 2017 9:33 am
First name: Dale
Last Name: Peterson
City: Bloomington
State: MN
OK. Do you have any tips on how to do that or what products are available?
PostPosted: Sat Dec 02, 2017 11:56 am
First name: Freeman
Last Name: Keller
Need to know a couple of things. When you say you want to "stain" the body, what exactly does that mean? Do you want an opaque (solid) color, to be able to see the wood grain through color or just to highlight grain? Do you want to use the same stain on both the maple and the mahogany? Are you trying to make them the same color?
Next, by "matte finish" do you mean a smooth finish that just doesn't have a high gloss or do you want more of an organic wood finish like you might see on furniture? Most guitar manufactures have guitars with a "semi gloss" finish - is that what you are after?
Lastly, what materials and techniques are you familiar with? Can you spray finish, use rattle cans, brush or wipe on finish?
PostPosted: Sat Dec 02, 2017 5:57 pm
First name: Dale
Last Name: Peterson
City: Bloomington
State: MN
Hi, Freeman.
I plan on using two different stains to create a gradient (for effect) and also to allow the maple grain to show though. I'm planning on using a darker color on the mahogany sides and back.
By 'matte finish' I'm meaning I want to have a flat, no gloss finish. Something that you may find on furniture.
Extra information: I'm planning on just using Tru-Oil on the neck for that natural feel. I don't know if that will be the look I'm going after or not, so I thought I would get other opinions.
PostPosted: Sat Dec 02, 2017 7:30 pm
First name: Freeman
Last Name: Keller
OK, Dale, that helps. A couple of things to consider, there are really two ways to get a satin or matte finish - either apply something that dries satin or use a very mild abrasive to knock the gloss off of a shiny finish. In the first category you have what I call the furniture finishes - tung oil, various varnishes and finishes that are intended to not be shiny (automotive primer is the best example but there are clear finishes that might work for you). The big problem with any of these is that your final coat is what you get - if you have any flaws like brush marks, wipe marks, orange peel, dust, runs... they are there to stay. (well, sorta, we'll come back to that)
Second way to do it is apply something that might come out glossier than you want and then knock that back with steel wool, scotch brite pads, automobile rubbing compound, etc. The advantage of this is that you can level sand the last coat if there are any flaws, then do the satin pretty much to the degree that you want. Obviously this would work with a satin finish material too. This is actually pretty common for people who finish with a glossy material but still want the satin on the back of their necks - a little 0000 steel wool will take that gloss right off (but it does come back with play).
One issue you will need to deal with is that mahogany is an "open pore" wood - it has tiny little pores that look like lines about 1/16" long and a few thousands wide. Maple does not have these pores. Most of us who deal with porous wood will fill them with a paste filler - you may decide that you like the look and want to keep them.
Your desire to do the staining also opens some potential issues. There are two kinds of stains - water based and alcohol based. Basically they soak into the wood and in many cases highlight grain. Often they soak into end grain much faster than cross grain and make it much darker. They can be used to pop the figure in woods like maple, and are frequently used to create sunbursts and shaded finishes. Traditional Gibson 'bursts were done by wiping stains directly into the wood, then clear coating over the top. Big problem here is that once you apply stain you are pretty much committed - if it does something unexpected its hard to back up. The other way to get color (and do sunbursts) is to add the dye to the finish itself - that is much easier to control the color (and can be sanded off if it doesn't look right) but doesn't have the depth that stained wood has.
There are a bunch of material choices and I have experience with only a few so I'll only talk about them. I do use tung oils and various varnishes when I do wood working, build a book shelf or an amp cabinet, but I don't use them on guitars. I want my guitars to look better than a book shelf. I build a class of guitars out of salvaged barn wood and use Tru-Oil on them - that gives me a nice warm organic glow, I can get a moderate gloss without looking "show car" wet look. It seems to look right on the barncasters and I use it on bodies and necks. Tru-Oil is very easy to apply - many very thin coats (I do two a day for 10 to 15 days), you can sand with 400 grit or 0000 steel wool each day. Let cure for 3 or 4 weeks and buff (or satinize) and its done. Here is one made out of 100 year old pine (by the way, pine is not a porous wood) with Tru-Oil lightly polished
My big concern with Tru-Oil would be applying over any stain and pore filler - I've never done it and think it might not work very well.
That kind of brings us to lacquer - it is the traditional finishing material for guitars, Gibson still uses it, and its honestly not that difficult for a home builder. Best is to apply with a compressor and gun but rattle cans are an acceptable method. You can get lacquer that is designed to dry to a satin finish and you can get tinted lacquer. Reranch and Stewart McDonald are good sources.
http://www.stewmac.com/Materials_and_Su ... cquer.html
If I was going to finish a guitar like I think you are describing, here are the steps I would take. I'm guessing your kit has a removable (screw on) neck - if so do the Tru-Oil thing as described above. If it has a glued on neck then I wouldn't try Tru-Oil at all, I would finish the neck on the guitar and then use 0000 steel wool on it
- sand to 320, mask the top and fretboard, pore fill with a paste filler (StewMac)
- pull the mask from the top, do whatever stain you want (I like Colortone stains in denatured alcohol)
- scrape bindings, seal with 2 or 3 coats of vinyl sealer (StewMac)
- scuff sand with 320, shoot 6 to 12 coats of satin lacquer, 3 coats per day, sand to 320 each day
- if you like the finish stop here. If you don't like it consider adding 3 coats of gloss lacquer
- let cure for 30 days (truely)
- sand out any imperfections with 600, 800, 1000, 1200 grits. Choices now might be 0000 steel wool for a little softer finish or hand applied automobile rubbing compound for a little more gloss. Don't use a buffer and don't use any product with silicon or wax
I'll add that the old rule of practice on scrap really applies here but if this is a kit you probably don't have any scrap. I happen to have both mahogany and flamed maple cutoffs - I would be happy to send you some pieces to experiment with (gratis)
I know this isn't exactly the look you are trying for but here is a LP that I build a few years ago and my "ice tea" burst
http://www.harmonycentral.com/forum/for ... 33-/page11
Also if you look at the Tribute series of guitars that Gibson is making now you might get some ideas. They are finished in satin lacquer, some with 'bursts and are pretty good bang for the buck guitars.
http://www.gibson.com/Products/Electric ... ibute.aspx
Hope this helps
PostPosted: Sun Dec 03, 2017 1:20 am
First name: Dale
Last Name: Peterson
City: Bloomington
State: MN
Wow. Freeman. Seriously good info you've provided! I really appreciate it!
So, my neck is a set neck (glue in). Why wouldn't you use Tru-Oil on the neck at all? Will it degrade the glue?
I just remembered there is a guitar with the finish that I'm essentially trying to achieve. It's a Schecter C1 (http://www.guitarcenter.com/Schecter-Gu ... staniac.gc). This may, in fact, be a tad too glossy for me, but I do like how it feels.
There have been a lot of people in my same position that have used diluted ink to get that really vibrant blue, red, purple color for a stain. Is that just a bad idea, or is it a viable solution to get those vibrant colors?
Thanks again!
PostPosted: Sun Dec 03, 2017 1:06 pm
First name: Freeman
Last Name: Keller
My concern with mixing an oil finish with a solvent finish on the same guitar is that there might be some bleed of one into the other no matter how well you mask them off. Most of the time when I see Tru-Oil used on a neck it is before they are assembled. That is the only way I've used it so since I have no other experience I tend to avoid recommending something. I don't think the oil will have any affect on the glue (assuming you are using Titebond or hot hide).
I've done a number of set neck guitars but have always used the same finish on the neck and body. This is one area I would definitely experiment on scrap.
As far as using ink for your stain, again, I have no experience. I've used commercial aniline dye to stain wood and to tint my finish - it is very concentrated and mixes with either alcohol or water for staining, and will dissolve directly in both water born and nitrocellulose lacquers (that is all I use for finishes). Here is a simple red guitar
It had a red stain applied directly to the wood, then sanded back to pop the grain in the maple. Next a seal coat followed by a bunch of coats of clear with a little of the same red dye mixed into the finish. Obviously I was going for the deep gloss but you could certainly make the same finish matte. The back of this guitar is also maple but the neck is mahogany and I used both the stain and tinted finish to try to match them as best I could (I should have made a maple neck)
ps - I had to laugh when I saw the link to that Schecter - a few years ago I installed a Sustainiac in a flying Vee - that always remains the guitar from hell
PostPosted: Mon Dec 04, 2017 2:05 am
First name: Joey
Last Name: Holliday
City: Palmetto
Zip/Postal Code: 34221
Thanks again!
I can't speak to dyes but yes you can use Tru Oil on the neck and just about any other finish on the body, but as Freeman mentioned you have to complete the tasks separately and let them cure before assembly. As a player I prefer the feel of a matte tru oil finish on the neck as it's not sticky but very smooth. The rest of the guitar I prefer semi gloss to glossy but that's just me. Tru Oil goes on fine over epoxy pore fills as well.
PostPosted: Mon Dec 04, 2017 9:10 am
First name: Dale
Last Name: Peterson
City: Bloomington
State: MN
Seriously, Guys, thanks for all the great tips on this. It's nice for us newb's to have your experience on this.
Thanks again!
PostPosted: Mon Dec 04, 2017 11:51 am
First name: Freeman
Last Name: Keller
Dale, I have some pieces of mahogany and some flamed maple and I'm happy to send it to you. PM me an address that can except a small package (would be USPS unless for some reason that doesn't work).
Also, there is a thread about wipe on poly and Tru-Oil on the main building forum - might be wise to check that out.
PostPosted: Fri Dec 15, 2017 12:35 pm
First name: Freeman
Last Name: Keller
Dale, here is a thread from the "other" lutherie forum where someone wants to use TruOil on the neck and nitro on the body. He is going to finish the parts separately and then glue together (which is the way I would do it) - question is about getting oil into the neck pocket.
http://www.mimf.com/phpbb/viewtopic.php?f=4&t=5339
PostPosted: Fri Dec 15, 2017 4:49 pm
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Zip/Postal Code: J2M 1R5
fingerstyle1978 wrote:
As a player I prefer the feel of a matte tru oil finish on the neck as it's not sticky but very smooth... Tru Oil goes on fine over epoxy pore fills as well.
I went through a phase where all my guitars had neck shafts finished with Tru-oil — for the feel. The shaft can be left uncoated during nitro application, then the oil applied such that the Tru-oil edge blends over the lacquer. Very difficult to detect the changeover after buffing, other than the slightly darker colour of the oil.
BUT, I can’t agree that “Tru-oil goes on fine over epoxy”. Certainly, if there is not a good barrier between the oil and the epoxy, at least some epoxies (Zpoxy, for one) will react over time to form the most annoying fuzzy feeling. It can be buffed out, but it comes back. I’ve refinished necks on two guitars with lacquer because of this, and I thought I had a good shellac coat under the oil. Be warned.
When I use an oil finish on a neck these days (and even when I don’t), pore fill is done on this surface with acrylic bead paste, with other surfaces filled with epoxy.
PostPosted: Fri Dec 15, 2017 11:36 pm
First name: Dale
Last Name: Peterson
City: Bloomington
State: MN
So, Tim Mullen, you are saying that I should seal the neck with the acrylic bead paste before using Tru-Oil on it?
PostPosted: Sat Dec 16, 2017 8:44 am
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
I said that I “pore fill” with acrylic bead paste. I seal with shellac. I am sure there are many other undercoat systems that work fine under Tru-oil. My main point was that epoxy was NOT good, in my experience.
PostPosted: Sat Dec 16, 2017 2:36 pm
First name: Joey
Last Name: Holliday
City: Palmetto
Thanks for sharing your experience Zpoxy. I've only used West systems epoxy and haven't had an issue yet. How long did it take for the problem to arise?
PostPosted: Sat Dec 16, 2017 3:32 pm
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
About 6-9 months. Around the time I was noticing also bad sink-back of the Zpoxy in the pores — the sinking pores continued to worsen over 2 or 3 years.
I switched to West Systems 205/207 but still stayed away from putting it on neck shafts as it’s such a PITA on that surface. A paste-type pore filler is MUCH easier there, IMHO, even if I use epoxy elsewhere.
Many others on this forum sing the praises of Zpoxy — not me.
